Bmw 328i 1996 touring boot lock broken
1996 BMW 328
AVARIL
the boot of my touring is locked shut and I cannot open it as some part of the lock has broken! I heard a noise whilst driving (sounded like a small metal part dropping to the bottom of the inside of the tailgate). I can get access to the inside of the car through the back seats and have tried to remove the plastic covers that would give me access to the lock and locking mechanism but unfortunately, they will not budge unless the tailgate is open.
I called BMW in Romford who told me that they were not aware of any method of getting the car open. BMW Park Lane told me that there are two plastic plugs right where the tailgate locking mechanism meets the car, the plugs need removing although he wasn't quite sure of what to do next! I removed the plugs but was unsuccessful in opening the boot.
I then called BMW Holland Park and their head mechanic told me I needed to loosen the panel on the tailgate as much as possible then try to kick it, which I definately do not want to do!!
I realise that the car is a little rare, however there must be a way of getting into the boot without causing too much damage!!
Any help would be appreciated![/b]
Apr 25, 2006 at 5:12 AM
2CARPRO JACK
  • 11,533 POSTS
Are there any bolts behind the plugs you removed that would unbolt the lock assembly from the body?
Apr 25, 2006 at 9:40 AM
AVARIL
The plugs that I removed are about 1.5 inches apart and the two holes they left are about the sizes of 5p pieces. Upon shining a torch in the holes, I can see no bolts at all. I got a price of £30 (from BMW) for that piece of plastic trim that is covering the lock assembly (the one with the two plugs in it) and am considering trying to cut/bend it/break it open to get to what is underneath, I just want to make sure that there isn't another way/ that I will actually be able to pop the boot open before I destroy the plastic part.
Apr 25, 2006 at 6:00 PM
