2001 BMW 325
DAVID6410
  • 2001 BMW 325
  • 6 CYL
  • 15,000 MILES
Where is the relay switch and where is the inertia shut off switch because my car won't start and I suspect that it is this and how do you fix this? When I start the car I hear a cranking sound but it won't start.
Monday, November 1st, 2010 AT 9:55 PM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Tuesday, November 2nd, 2010 AT 12:59 AM
