1999 BMW 323i No Reverse
RAYR
hi,
my 1999 bmw 323i automatic 240000kms 2.5l refuses to go reverse, when I put it in reverse it is like it is in neutral position. it happened a couple weeks ago and was fine the next day but have the same problem again today on and off 3 times. can you please tell me what to do is there any things like electrical fuse or something I shold check
thanks in advance and will mail a donation by mail if I can have an address to mail to.
Oct 25, 2007 at 5:42 PM
DOCHAGERTY
  • 9,606 POSTS
there is something internally wrong on those transmissions. replacement is the only option I know of
Oct 29, 2007 at 3:20 AM
ROSSBY
WHILE DRIVING OVER A SPEED BUMP IN MY APARTMENT COMPLEX I CAME DOWN REALY HARD ON THE TOP OF ONE OF THE SPEED BUMPS. AS I WAS LEAVING LATER THAT DAY I PLACE THE CAR IN REVERSE ,HEARD A LOUD NOISE AND COULD NOT MOVE IN REVERSE. I AM STILL ABLE TO DRIVE JUST NOT IN THE REVERSE MODE WHAT CUOLD IT BE?
Nov 26, 2007 at 8:07 AM
DOCHAGERTY
  • 9,606 POSTS
This will require a technician to inspect and advise. I am in cyberspace and can only imagine what happened.
Nov 26, 2007 at 11:08 AM
Suggested Repair
Have a technician inspect the automatic transmission. An internal fault is likely, and replacement is the only known repair option.
Conversation Summary
The owner of a 1999 BMW 323i automatic says reverse acts like neutral, sometimes returning briefly then failing again, and asks about fuses. The expert says the transmission has an internal problem and replacement is the only known option. A follow-up describes reverse loss with a loud noise after a hard speed-bump impact; the expert says a technician must inspect and advise.
