The air conditioner continues to work....so far.....and blows cold air, however, it will blow HI or LOW intermittently, and the controls on the dash oftentimes do not seem to change that. It will be set on a lower setting, and all of a sudden you will be getting blasted with cold air and vice versa. Also, when the car is turned off, key removed from the ignition, the air will continue to blow, sometimes for several minutes. What's going on?!?
Aug 12, 2009 at 2:41 AM
