1993 BMW 320 Steering and Gas Guage
1993 BMW 320
212,222 MILES • 6 CYL • AWD • AUTOMATIC
KENZO128
Where can i see the steering fluid and i have the problem for my gauge that my gas if full but it show empty in my gauge what will be the solution for this
Jan 29, 2009 at 7:14 PM
DOCHAGERTY
  • 9,606 POSTS
The power steering reservoir is located down low and in front of the left front shock tower. It is a dark brown cylindrical container with a round black plastic screw on cap and probably will require a long funnel to fill. The fuel gauge problem could be indicative of two issues, first is deposits on the sending units and second a possible internal fault in the instrument cluster, or perhaps a loose connection or ground. Does the idiot light for low fuel still work? If I had to start somewhere, I would replace the fuel sending units as there is a bulletin regarding an upgrade to deal with "oxidized" fuel additives that cause said deposits
Jan 30, 2009 at 3:44 AM
KENZO128
Thank you sir for the information its a big help, yes the idiot light are still lighting and gas is full, fuel additive do you have any idea if available here in Unite Arab Emirates? thank you more power to this site.....
Jan 30, 2009 at 5:12 AM
DOCHAGERTY
  • 9,606 POSTS
Thanks.
Jan 30, 2009 at 10:13 AM
