1997 BMW 318 gets hot at idol
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
RED318TI
i can drive it for hours and it wont get hot but if it sets at an idol for 5 to 10 minutes it starts to get hot. then i rev the engine or drive it and the temp go right back down. help going crazy.
Apr 25, 2008 at 3:17 PM
  • 75,988 POSTS
Replace the thermostat and make sure your coolant level is correct and the cooling fan is coming on.
Apr 25, 2008 at 3:36 PM
RED318TI
thermosatat was replaced befor i replaced head gasket do you think it still might be bad.
Apr 25, 2008 at 5:40 PM
  • 75,988 POSTS
Take it back out and test it Or leave it out and see what happens this will tell you something at idle on that time frame- How old is the radiator cap?
Apr 25, 2008 at 5:45 PM
DOCHAGERTY
  • 9,606 POSTS
Is there a fan and a fan clutch driven off the water pump? If not replace them with part# 11-52-1-723-918 & 11-52-1-723-363
Apr 26, 2008 at 2:52 AM
RED318TI
the thermostat and where the hoses connect is all one piece i do have an old one. will that make it run cooler or hotter.
Apr 26, 2008 at 9:14 AM
