1995 BMW 318 engine makes ticking/taps noise after it start
TERRYGEORGE5833
Engine Mechanical problem
1995 BMW 318 4 cyl Automatic 120000 miles
ENGINE MAKES TAPPING NOISE AS ENGINE WARMS UP STARTING TO DO IT ALL THE TIME
Jun 4, 2009 at 11:04 PM
TERRYGEORGE5833
ENGINE MAKES TAPPING NOISE AS IT WARMS UP GETTING LOUDER
Jun 4, 2009 at 11:14 PM
DOCHAGERTY
  • 9,606 POSTS
The hydraulic lash adjusters are noisy when they don't pump up, replacement is the only sure way to repair this. You might be able to get it to stop if you use some sort of oil treatment or you could try this, allow engine to reach full operating temperature and then go for a drive where you can hold it in a lower gear to allow the engine RPMs to go to 4k and just hold it there for several minutes, Volvo uses the same lash adjusters and this was a trick I learned from them, it does not always work. Good luck mate ♥
Jun 5, 2009 at 2:45 AM
