1985 BMW 318 FUEL INJETION ISSUE
1985 BMW 318
DEBOEFS
Engine Performance problem
1985 BMW 318 4 cyl Two Wheel Drive 184000 miles
WHEN THE CAR IS AT AN IDOL IT IS FINE AND DOESN'T MISS AT ALL AND WHEN I PUSH THE PEDDLE PAST HALF WAY ACCELERATING FIRMLY IT IS FINE, BUT IN THE PEDDLE RANGE BETWEEN IDOL AND OVER HALF WAY THE CAR CUTS OUT HARD AND SURGES UP AND DOWN DRASTICALLY MAKING IT VERY DIFFICULT TO DRIVE IT JERKS YOU BACK AND FORTH AS YOU TRY TO DRIVE.
Mar 24, 2009 at 4:22 PM
DOCHAGERTY
  • CERTIFIED EXPERT
  • 9,603 POSTS
Possibly a worn air flow meter or it could be an engine wiring harness issue. The harness shorts out and causes all sorts of problems.
Mar 25, 2009 at 12:38 AM
60'S CHILD
all so check the tps wear in this part of the sensors range can cause bucking
Jan 30, 2010 at 10:53 AM
