1995 BMW 316 Automatic
Drive a 1995 316im mileage around 188, 000kms. I have noticed afer regularly using my car often, it loses water from the coolant, and at times green in colour. However, the thermostat is still in the middle range. There are also some other times when I put water into the coolant right to the top, and just go for a 5min drive, and the coolant levels will be right at the bottom, with no visible leaking. On a couple occassions, the car does over heat and the thermostat is in the red.
SPONSORED LINKS
Sunday, August 1st, 2010 AT 8:16 AM
