This could be a speed sensor issue or something more serious. I would suggest we start with checking codes and finding out what codes we have. Here are a couple guides that will help with this. Clearly the ABS guide is not the traction control system but pulling the codes from these two systems are similar.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
If you have a scanner that can pull these codes then it is pretty simple as it will just provide them for you. Here are a couple videos that will help as well:
The first is how to test a wheel speed sensor if we have any of these codes. If we do you can go ahead and do this test.
https://www.youtube.com/watch?v=rTtAnsOlZU4
The next is a video on how to pull ABS codes in case you need this as well.
https://www.youtube.com/watch?v=ANWVTh2RQoQ
Please run through this info and let us know what you find and we can go from there.
Thanks
SPONSORED LINKS
Tuesday, August 10th, 2021 AT 4:59 PM
