Blew up posi
200,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CALEB STEWART
I blew up my posi and I need to know about the gearing. if I go hire gearing what are the pros and cons and what if I go lower?
Jun 5, 2017 at 2:30 AM
CARADIODOC
  • 34,415 POSTS
You listed this as a four-wheel-drive. Both axles need to be the same gear ratio.
A higher gear ratio will give you more pulling torque, more engine noise, and more low-speed "get-up-and-go". It may cause a decrease in fuel mileage, but that can be offset by the engine not having to work so hard.
Jun 5, 2017 at 12:29 PM
