Blew a fuse or electrical system on my 2010 Dodge Avenger
2010 DODGE AVENGER
94,000 MILES
THREAD7
Argghhhh!!! I was trying to remove corrosion on the battery terminals and accidentally caused a spark. Now the car won't start. Nothing happens when I turn the key. The interior lights still do work fine. I looked in the fuse box but there are so many fuses I don't know what to check. What should I do? I have a multimeter if that helps.
Here is a photo of my fuse box. http://imgur.com/A3U3YDI
Not even sure if that is where I should start.
Feb 19, 2016 at 3:02 AM
WRENCHTECH
  • 20,761 POSTS
The larger ones you just physically look at to see if the strip is melted. All the other ones you test with a test light with the key on. There is a test point on each end of the fuse.
Feb 19, 2016 at 3:09 AM
