Blend door not moving from defrost position
100,000 MILES • 3.6L • 4 CYL • 2WD • AUTOMATIC
DINKY1950USA
The air is blowing out of the defroster vents, very little on the floor. None out the A/C vents even when you have the system out of automatic and manually switch it to A/C vents. I removed the HVAC fuse for a minute and started the car, then waited 40 seconds before turning the controls on and it still is in the defrost position.
May 9, 2021 at 8:28 AM
STEVE W.
  • 15,413 POSTS
That sounds like a bad mode door actuator. Item 5 in the image. To get to it you need to remove the insulator panel under the glove box, then the glove box itself by removing the screws that attach it to the panel. The actuator is then inside that opening on the left side. You remove the 3 screws and pull the actuator out. Put the replacement in and then connect it. Next pull the same fuse you did the first time and reset the system like you did the first time. That should initialize the actuator.
I have replaced them simply by dropping the glove box down but you need to be able to work by feel doing it that way as you can't get light in there to see.
May 9, 2021 at 9:17 AM
DINKY1950USA
Already went and picked up a new actuator and that fixed the problem. Thank you for your reply.
May 9, 2021 at 9:43 AM
STEVE W.
  • 15,413 POSTS
Good to hear you got it taken care of. Thank you for using 2CarPros.
May 9, 2021 at 1:26 PM
