Blend door actuator location
150,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ISAAC WEXLER
Hi, all vents are working, except the demister on top. I took the fascia out. Turned key on for heater matrix could feel strong air from side/front ducts but very little from ducts that connect to demister. Is this a blend door actuator problem? Not moving the air through the vent ducts properly. Where would the actuator be located that controls the vents so I can check and replace it? Unfortunately my workshop manual has nothing on HVAC actuators? Also the cogs/cable on the heating control connected to some circular thing was working and turning fine.
Mar 27, 2019 at 9:23 PM
SCGRANTURISMO
  • 4,897 POSTS
I have included the information that you have requested in the diagrams down below. I have also included a link for you to go to below.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
Please go through all the information and get back to us with what you find out.
Thanks,
Alex
2CarPros
Mar 27, 2019 at 10:17 PM
