Bleeding the FRONT BRAKES
2006 CHEVROLET SILVERADO
180,000 MILES • 5.6L • 4WD • AUTOMATIC
BRITTNEY IANNIELLO
Changed the calipar on front driver side and brake pad and shoes and rotar. On front passenger just pads were replaced. Is there a special way to just bleed the front brakes.?
Apr 15, 2018 at 4:52 PM
  • CERTIFIED EXPERT
Good morning.
No, but if got air into the system and it got to the ABS, then you need a scan tool to bleed the ABS system. you cannot manually bleed the ABS.
Have you tried bleeding the system yet?
Apr 16, 2018 at 4:44 AM
