Bleeding the Brakes.
150,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
NOTAPROMIKE
  • 66 POSTS
I replaced 2 rrusted leaking brake lines that run from the master cylinder to the ABS control box. (The ABS does not work). I did not attempt to bleed the new lines at the ABS control box. I started at the right rear wheel, then left rear wheel, then left front and right front. The car was NOT running when I was bleeding the air out of the system.Now, I have very little brakes and the pedal goes to the floor. The master cylinder is full. What am I doing wrong? Please help. Thank you. Notapromike.
Apr 14, 2016 at 12:03 AM
HMAC300
  • 48,601 POSTS
nothing abs can be tough to bleed there are two things you can do here, rent a power bleeder an dit may take up to 3 qts of fluid to bleed it or take to a pro so he can bleed it with his scanner to open the valves of the abs unit.
Apr 14, 2016 at 2:35 AM
