bleeding brakes after putting new hose in on the left hand wheel
2004 FORD FALCON
299,879 MILES • V6 • AUTOMATIC
MORANDAT
Ok heres the problem, I dont have the funds to fix my bleeder screw/valve because its rounded, am I risking my chances of not bleeding that section of my wheel and just putting brake fluid in the master cylinder and be ok to drive?
Feb 2, 2014 at 5:33 PM
MORANDAT
Left hand front wheel
Feb 2, 2014 at 5:35 PM
HMAC300
  • 48,601 POSTS
it really shold be bled. if you take a propane torch and heat around the bleeder screw then spray penetrating oil on it (it'll smoke) then tap with a small hammer around the bleeder. do that a couple of times and see if the bleeder will break loose, normally it will. then replace the bleeder screw. then normally bleed the system.
Feb 3, 2014 at 12:10 AM
