If you did the pads only then there should be no need to bleed the brakes unless you opened the caliper bleeder to do pads.
If you did open it then a simple bleed should take care of the problem. Bleed sequence is as follow.
right rear, left rear, right front, and left front. And if you still have a spongy pedal then as HMAC300 has stated, you will need a scan tool to bleed the ABS if it is equipped with ABS.
Let us know how it goes.
May 19, 2017 at 3:26 PM
