Battery put in backwards
27,000 MILES • V8 • RWD • MANUAL
GLICKT13
I am currently working on the truck listed above. I got in a hurry and hooked the battery up backwards because I was not paying attention. Now, there is no power to the truck at all, but the battery tests fine and still works on other devices.
Feb 1, 2017 at 4:29 AM
SATURNTECH9
  • 30,869 POSTS
Have checked all the fuses yet? I am sure you blew some fuses from doing that.
Feb 1, 2017 at 4:46 AM
STEVE W.
  • 15,397 POSTS
Check all the fuses. the fusible links and the alternator for damage.
The good thing is that it is a 1975 so you should not have much for computer hardware other than spark control.
Feb 2, 2017 at 12:01 AM
GLICKT13
I checked all the fuses I could find and they were all still good. I replaced a couple just in case, but there still is not any power at all except in the battery cables. I replaced the starter solenoid/relay and still nothing. It appears all the fuses are in the box and none of them in any of the wire links.
Feb 2, 2017 at 3:24 AM
STEVE W.
  • 15,397 POSTS
Take a test light. Connect it to ground and start probing at the battery and then to the end of each wire from the battery to the fuse box.
Feb 2, 2017 at 4:02 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like a good plan something is burned up or blown .
Feb 2, 2017 at 5:04 AM
