battery, powering steering, and dash lights not working properly
140,000 MILES • V6 • 4WD • AUTOMATIC
MATTGOOD
I went out to take my daughter to school, started my car and I noticed all my dash lights were on and it was flickering like the radio, dash keep going out, then back on every 2 seconds and had no power steering. I turned the car off and tried to start it just clicked like battery was drained. went in to get my tester and battery is fully charge. I tried to start it and it started right up but the same issue occurred. I checked fuses and all were good. tried to start again and it just clicked like the battery was drained. But the battery is still charged. I'm thinking if the battery isn't draining then it can't be alternator but I'm not positive. Please any help would be greatly appreciated thanks.
Jan 5, 2022 at 2:05 AM
  • 110,248 POSTS
It sounds like there is a voltage issue, but not likely the result of the battery or alternator. Have you checked to make sure the battery terminals are both clean and tight? Also, check the ground connections at the engine and the body. Just follow the ground cable and make sure the connections are clean and tight.
Here is a link you may find of interest:
Jan 5, 2022 at 10:09 AM
