Battery Question
22 MILES • 4 CYL • 4WD • AUTOMATIC
DOMINICLYNN
Hello all, my friend and I bought a car battery at the same day. But unfortunately after one year my car battery is dead, but my friend's car battery is working well. How can that happen? Can you suggest an online place for to purchase a replacement battery with affordable prices.
May 17, 2016 at 7:36 PM
HMAC300
  • 48,601 POSTS
if the battery is a year old and dead and will not charge it should be under warranty and should not cost you anything to replace it if you take it back where you bought it.
May 17, 2016 at 11:03 PM
BATTERYBHAI
  • 5 POSTS
When you are not maintaining battery well and drive daily. Most of the cases battery are dead before its set time. If you want use battery longer then follow the tips.
*Drive your vehicle regularly.
*Have your engine serviced regularly.
*Check the battery charging rate time to time.
*Avoid draining.
*Keep the car battery case clean.
*Avoid jump start a flat car battery.
May 18, 2016 at 4:18 PM
DOMINICLYNN
Thanks for your useful suggestions.
May 18, 2016 at 4:25 PM
  • 55,781 POSTS
Hey DOMINICLYNN,
You could have a electrical drain problem as well, check this link out.
https://www.2carpros.com/articles/car-battery-dead-overnight
let us know what you find
May 21, 2016 at 6:22 AM
