Battery draw
208,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHN_123
Battery drains flat over night. No lights on during this. ABS and brake light come on during idle shuts off after driving for a couple minutes.
Nov 17, 2017 at 11:53 PM
STEVE W.
  • 15,385 POSTS
You need to perform a parasitic draw test to determine what is staying on. One way to do this is to remove the negative battery connection, then connect a test light in between. It will be on because of the draw. Then you start removing fuses one at a time until you find the reason for the battery drain. I would also test the battery to be sure it is okay, internal shorting can cause the same thing.
https://www.2carpros.com/articles/car-battery-dead-overnight
If you have a good voltmeter there is a better way. It does not cause modules to wake up or give false test results. Go yo you tube and search for
" The Best Way TO Perform a Parasitic Draw Test" it is a video by the humble mechanic, it is much faster and does not cause other issues like disconnecting the battery can.
Nov 18, 2017 at 6:35 AM
