Battery drains after a week of not running
1997 GMC SONOMA
130,000 MILES
RDRR62
My son has a 97 GMC Sonoma that if he lets it sit for a few days the battery is drained and won't start. I have replaced the battery with a new one. I had 2 different parts stores bench test the alternator and each one came up with everything being at normal performance. I have debated about clipping the vanity lights on the visors since the covers are broken, not sure they shut off correctly. The box is currently unattached due to some work being done on the truck.
Jun 23, 2013 at 11:41 AM
  • 110,240 POSTS
Start by checking to see if there is a draw on the battery when everything is off. If there is, then remove one fuse at a time until you find the circuit that is causing the problem. There are directions on our homepage for this procedure.
Jun 23, 2013 at 1:53 PM
