Battery draining fast
315,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
GEMINI777
A couple of days ago i went to town, when I tried to start car it would not. It did jump off and was able to get it home. It will run for a minute or two then the battery gauge slowly drops and then it shuts off. I assumed the alternator was bad, I have just put a brand new one on there, and it is still doing it. Battery has a good charge. What else could it be?
Jan 10, 2017 at 1:57 AM
CARADIODOC
  • 34,414 POSTS
Measure the battery voltage while the engine is running and tell me what you find.
Jan 10, 2017 at 7:02 AM
JOHNNY G.JR
  • 320 POSTS
If battery is so/so alternator will not charge. slowly charge the battery overnight. Take it to a local garage or parts store and have it load tested. from there proceed with alternator testing, a reading from 13-14.7 would be good depending upon the load placed on it, radio, lights, fan, defroster,etc.
Jan 10, 2017 at 7:42 AM
  • 55,743 POSTS
Hey GEMINI777,
Here are a couple easy tests that will show you what the problem is.
and
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Jan 14, 2017 at 3:51 PM
