Battery drainage
80,000 MILES
TOYOTA2004
If it is staying at parking more than one week, battery drains. I used solar power during parking to charge the battery, but it did not help.
May 8, 2022 at 10:27 AM
SQM
  • 6,383 POSTS
Sounds like the vehicle has excessive parasitic draw (current drain) on the battery.
Every electrical circuit with a battery will have some amount of parasitic draw, however it can become excessive due to any number of faulty components. Like a glove box light staying on or a shorted window switch etc.
In order to find the culprit, you will have to use a multimeter and check the current drain on the battery as you remove different fuses/relays.
Take a look at this video, it shows exactly what to do to find the draw:
https://youtu.be/z5F7WpgjaRs
Here is a helpful guide:
https://www.2carpros.com/articles/car-battery-dead-overnight
Let me know of any questions.
May 8, 2022 at 3:14 PM
