battery drain
90,000 MILES • 7.5L • V8 • RWD • AUTOMATIC
C_CLARK2255
after trying three new batteries the battery still is draining over night. the alternator tested good. also, the ground battery cable has a charge going to it so when i hold the test light onto it the test light lights up. how can i fix this drain? what do i look for?
Oct 6, 2016 at 2:24 AM
HMAC300
  • 48,601 POSTS
you need to do a parasitic draw test to see what is doing it. start with glove box/trunk/hood lights first . as those were the big ones that caused it on the earlier models. this article may help.
https://www.2carpros.com/articles/car-battery-dead-overnight
Oct 6, 2016 at 5:10 AM
