Battery will not hold a charge
75,000 MILES • 4 CYL • 4WD • AUTOMATIC
JOE HOLCOMBE
I have used a minimax and will start but remove it and the engine shuts off. Would it be better to just have it towed to a mechanic? After the cables are removed there is no power in the battery.
Jan 29, 2022 at 3:30 AM
  • 110,248 POSTS
It sounds like the battery is bad or the alternator isn't keeping it charged. Do me a favor. Disconnect the battery and charge it to see if it then will hold a charge. If you don't have a charger, most parts stores will do it for you free of charge.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
I really need to start at this point. If you have already tried this, let me know.
Jan 29, 2022 at 7:20 AM
JOE HOLCOMBE
I have not tried this idea yet but will do it. Will let you know. Thanks.
Jan 31, 2022 at 3:09 AM
  • 110,248 POSTS
No problem. Actually, if you do have a charger at home, remove the battery and charge it. Before reinstalling it into the vehicle, have it load tested at a parts store. Most will do it for you free of charge. I just want to make sure there isn't something draining the battery as soon as it's reconnected.
One last thought. Because I don't know where you are located, often I don't mention this. However, if you are near something like an AutoZone, they will actually charge and test it for you right at the store. That makes it easier if you don't own the charger.
I will watch for your reply.
Jan 31, 2022 at 9:21 AM
