Regular battery location in a hybrid
100,000 MILES
CJLUV2000
where is the location of the regular battery in the car listed above hybrid and where exactly do i jump start it?
Jun 20, 2019 at 2:43 AM
STEVE W.
  • 15,390 POSTS
Welcome to 2CarPros. The 12 volt battery is remote mounted on your truck, it is mounted to the frame rail under the drivers side.
Jump starting it is done using the remote positive battery terminal located near the oil dipstick and the negative terminal located on the drivers side inner fender.
However either battery can go low and cause a no start. To tell which it is the dash lights should help. If it's the 12 volt battery that is at fault the battery light on the dash will come on. If it is the high voltage pack that is the problem the radio/nav unit will show "insufficient charge" If it's the 12 volt battery you can use the remote terminals to start it. If it is the high voltage pack you will need a scan tool to enable the charging system to charge the HV pack.
Jun 20, 2019 at 5:25 AM
