Not cranking or starting
84,000 MILES • 4 CYL • 2WD • AUTOMATIC
LISA DI FONZO HARNESS
Car will not turn over, not sound when turning the key.all electronics and lights do come on? what could it be?
Nov 19, 2017 at 11:14 PM
F4I_GUY
  • 3,302 POSTS
Sounds like it may be a starter motor.
Here is a link from our website with all the information you need:
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
Now, it still may be the battery, it is always best to check the voltage first. It should be above twelve volts, while being cranked it should not drop below 9.6 volts. Ensure that the battery is okay before moving on to the starter. Below will be a battery link.
https://www.2carpros.com/articles/how-a-car-battery-works
Nov 20, 2017 at 3:33 AM
