Bad Brake Scrub
101,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
TURNAD1
Just did a rear pads/rotors job. Ever since, there is a heavy scrubbing/light grinding sound. Checked pads/calipers and everything looks to be seated properly. I notice its worst when I drive in a straight line. When I turn it subsides. Any suggestions?
Apr 16, 2017 at 5:50 AM
CARADIODOC
  • 34,415 POSTS
The most common cause of this type of noise after replacing parts is the metal splash shield got bent and is rubbing on the edge of the rotor. Another source of a crunching noise is failure to use special high-temperature brake grease around the rotor's center hole. That crunching occurs more commonly from the front, and mostly when cornering, not when going straight.
Apr 17, 2017 at 10:38 AM
