Backfire
134,000 MILES • 2.4L • 4 CYL • RWD • MANUAL
LANGING
Single backfire, occasionally, on start-up.
As engine is trying to start, starter motor engaged and turning the crank, sometimes there will be a 'muffled' explosion thump-like noise emitted from the engine bay.
Have not isolated exactly where the sound comes from, but have long thought it was inside the air intake tube, prior to the throttle body.
Problem has long standing, because I never figured it needed attention, being that it happens so infrequently.
When I began a search for information on engine backfires, I happened onto your website, which explained that backfires can cause damage. That is why I signed up.
Jul 20, 2017 at 8:09 AM
HMAC300
  • 48,601 POSTS
See our handy link on backfires and what to do about them. it may be just in need of spark plugs etc.
https://www.2carpros.com/articles/engine-backfires-while-running
Jul 20, 2017 at 8:41 AM
LANGING
This is not a case of backfires while running. Only happens when attempting to start, prior to running.
Jul 20, 2017 at 8:49 PM
  • 55,583 POSTS
Yes this could be the ignition system cross firing into a cylinder with the intake valve open causing the backfire. Do plugs and wires here is a video to help you get the problem fixed.
https://youtu.be/rU6uxV5dLoA
and
https://www.2carpros.com/articles/how-to-change-spark-plugs
and it might be if you have a large leak in the air intake boot. Here is a video so you can check that.
https://youtu.be/h8jOlZubz0c
Cheers, Ken
Jul 21, 2017 at 7:22 AM
LANGING
Thanks, Ken. Haven't had time YET to change out the spark plugs, but will do that.
What is 'cross-firing' and why does it happen?
Have a question about the air intake boot. Before I toss money at a new boot, how do I determine that there is actually a hole in it? Or, what did you do to diagnose it as a problem?
Sometime back, I had to replace the VSV for the EGR, and cleaned out the throttle body along with the EGR system. At that time I had to remove the air boot and it did not seem to be in bad condition, visually.
Jul 21, 2017 at 8:52 AM
HMAC300
  • 48,601 POSTS
just look for a hole in duct work normally between maf and engine that is where it will cause it to idle /run funny
Jul 21, 2017 at 10:01 AM
