Sometimes at night when it's cold I back fire through the intake. happens right after I drive it and start it up, twenty minutes later once it blew off the PVC valve. I have to replace the housing last time it blew off vacuum lines. sometimes at work in day I start it and let it idle and I can hear little piping sounds almost sounds like when a spark plug wire arch's against metal. I have all new plugs, new wires, new fuel injectors, and new ignition control module. plus it seems takes longer to start up, but when I press the gas petal at rev it up upon start up it evens out.
Dec 22, 2018 at 12:18 PM
