Back brakes wearing fast and squeak to front.
200 MILES
HOLDEN67
Going through rear brake pads fast, no towing. Front pads don't seem to wear but have small squeal under braking."....................................................................................
Oct 18, 2013 at 10:07 AM
  • 110,251 POSTS
Have you checked to see if the calipers are sticking?
Oct 18, 2013 at 12:12 PM
HOLDEN67
Haven't but had rear pads done 4weeks ago an nothing mentioned there. My guess is they are fine as the car brakes well overall. How is the car adjusted for pressure front to rear ? Ragards Mark.
Oct 18, 2013 at 5:19 PM
  • 110,251 POSTS
Mark:
The Front brakes should do aprox 60% of the stopping and the rear 40%. The fronts always wear out first. That is what is making me think you have a stuck calipers or a bad rubber brake hose that has collapsed inside and will not allow the fluid to return properly when the brakes are released.
Oct 19, 2013 at 7:19 AM
