Axle seals and bearings
155,945 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MICHAELPRICE
My question to you is, in your video to take off the axles and replace the seals and bearings will both axles come out just by removing at c-clip alone? Also, if you have rear drum brakes do you need to remove the brakes itself?
Oct 15, 2017 at 4:30 AM
  • 55,766 POSTS
Yes you can just pull the axles out after the c clip has been removed.
Here is the video in question:
https://youtu.be/zarxKsspr3s
On older cars you do not need to remove the rear brake shoes to do the job just the brake drum.
Cheers, Ken
Oct 16, 2017 at 9:24 AM
