brake and turn signals
163,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
MCCARTE3
Left side tail light quit working. Replaced fuse kept blowing. Got it to work for a few minutes then all my lights went out except headlights. Replaced all fuses and checked them, but still could not get brake lights or turn signals. so replaced switch that was by the top of brake pedal. Then brake lights come on but do not get bright when stepping on pedal. Turn signals still do not work replaced flasher by the fuse box panel on drivers side. Now trying to find the signal relay is supposed to be by or near top of brake pedal under steering column. Cannot find it also now speedometer and gauges ate not working and back up lights are on. No hazards either.
Jul 2, 2017 at 12:31 PM
CARADIODOC
  • 34,414 POSTS
If all these symptoms are related and started acting up at the same time, forget the flasher. That has nothing to do with the brake lights. Instead, you need to look for things all those systems have in common. The best suspect is the ground circuit for all of those lights. Also, I assume you mean the back-up lights turn on when they are not supposed to be on. That is another important clue. When lights operate at the wrong time, the ground circuit is usually involved in the defect.
Start by inspecting the wiring harness. The ground wire will be bolted to the body someplace near those lights. Look for a terminal that is corroded off or the wire is broken. If you do not find anything visually, you will need a voltmeter, and I will look up a wiring diagram and tell you where to take the measurements.
Jul 2, 2017 at 1:21 PM
MCCARTE3
Okay thank you. Will need the diagram!
Jul 3, 2017 at 12:10 AM
CARADIODOC
  • 34,414 POSTS
Did you do the visual inspection? Did you find a broken wire?
Jul 3, 2017 at 2:10 PM
MCCARTE3
I rechanged brake sensor. Now wnen turn on lights all of them come on except turn signals
Jul 4, 2017 at 10:29 AM
CARADIODOC
  • 34,414 POSTS
Please be specific. Which switch are you turning on? Exactly which lights are turning on? Are you saying some lights turn on just by replacing the brake light switch, even when the brake pedal isn't pressed?
I was hoping to solve this sooner. I'll be out of town at the Iola Old Car Show swap meet until Saturday night, so don't panic if I don't get back to you right away. Internet access is real poor there because over 100,000 people are trying to use it at night.
Jul 4, 2017 at 10:57 AM
MCCARTE3
Ok checked every fuse for a short circuit. None found. Found ground wires all good. Took apart brake switch again reinstalled put in new fuses. Hazards come on automatically when try to use turn signals still makes clicking noise but no turn signals. Brake light works fine when only have dayligjts on but as soon as I turn on headligjts all the brake lights come on and stay on. I checked the wires wthat connect into the the brake pedal button and found one that was meltedin the middle. Thrte are four wires that connect to the brake pedal switch and the one that was melted was/is ligjt green.I put black tape around it. Had noticed these wires were really hot when I changed brake pedal switch.
Jul 14, 2017 at 11:30 PM
CARADIODOC
  • 34,414 POSTS
I can't find any reference to an automatic transmission for this model. All my diagrams are for a manual transmission. The second pair of wires on the brake light switch is for the cruise control. It shows a dark green / red and a pink wire for that function.
The brake light part of the circuit uses an orange wire for the 12 volt feed, and a brown wire. I think where I would start, since you already found a melted wire, is to unplug the brake light switch, then use a stretched-out paper clip to connect the brown and orange wires together in the connector. Doing that should turn on the brake lights, even with the ignition switch off. Check if that function works. Also check if that makes any front bulbs turn on.
If everything looks right so far, turn the ignition switch on, then see if the signal lights work properly. If they do not, remove the "Backup Lamp" fuse, number 5, a ten-amp, then see what happens. That feeds the pink wire to the brake light switch. If things change with that fuse removed, that pink wire would have to be melted to the point of touching one of the brake switch wires.
The even better suspect is still a bad ground in the rear. Remove the paper clip from the brake light switch, and leave that switch unplugged. Now see what the signals do. The rear signals and the brake lights are different bulbs and are not related to each other, . . . except that the left brake light bulb and all the tail lights share a common ground point.
Actually, I'm going to have to stop here until you update on what you find this far. The wiring diagram is real confusing. According to it, you do not have a right tail lamp or left or right brake lights! I'm guessing that is not true. Also, tell me exactly how many bulbs you have in one rear lamp assembly, and if you can figure out if the stop lamp filament is the same one that's used for the signal. The diagram shows them as two totally different bulbs, but I'm not sure if that's right.
Jul 16, 2017 at 3:50 PM
