automatic transmition
42,000 MILES
KILLKENNY59
Hi .
I have a erratic problem with 3rd gear changing up to early with a feel of clutch slip.This problem is not always present when it is not it goes through the gears faultlessly.I have no info on history as i only just purchased the car the service book only has 2 service stamps.atf checked following hand book instructions oil level is ok so i have decided to change atf oil to see if this solves my problem i am using Fuchs 4400 can you tell me if there is a auto transmission filter i need to change if so where can i purchase a replacement. amica reg w366 ppf year 2000
cheers ken
Apr 29, 2013 at 1:11 AM
KHLOW2008
  • 41,812 POSTS
The filter is within the oil pan and has to be removed to access. Seems like there is a slight pressure leak when upshifting to 3rd and this is internal. A pressure test would be recommended to verify.
Apr 30, 2013 at 1:09 PM
