Code P01192 keeps turning on
153,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
GAMY0524
  • 10 POSTS
I cannot locate the torque converter clutch solenoid. Is it external or internal? Do you have an image of the wiring harness so I can identify it? This code keeps coming back whenever I drive it on the freeway. Thanks in advance for the help.
May 12, 2022 at 12:21 PM
BORIS K
  • 836 POSTS
01192 - Torque Converter Lock-Up Clutch
01192 - Torque Converter Lock-Up Clutch: Mechanical Malfunction
Possible Symptoms.
Torque Converter Lock-Up Clutch slipping
Possible Causes.
Torque Converter Lock-Up Clutch faulty
Valve Body faulty
Internal Failure in Transmission
Possible Solutions/
Check Torque Converter Lock-Up Clutch Slip
It can be checked with a suitable diagnostic tool.
Road test the vehicle and check live data from input and output shaft speed sensors.
In fourth gear, converter clutch locked, the in and output speeds should be very similar, no more than 50 RPMs difference.
A common issue is a worn valve body causing hydraulic pressure loss.
The lock up solenoid is located on the valve body inside the transmission oil pan.
A good video on the 4-speed automatic transmission.
https://youtu.be/V0xonOFOprY
This video is for a transporter, but the transmission is very similar.
Hope this helps.
Cheers, Boris
May 12, 2022 at 8:44 PM
