Automatic starting system upgrade
200 MILES • 2.4L • 4 CYL • TURBO • 4WD • AUTOMATIC
BENJIE80
  • 5 POSTS
Is it possible to modify and install an autostart function on my 2019 Honda CRV LX?
Sep 30, 2019 at 3:35 AM
STEVE W.
  • 15,388 POSTS
Welcome to 2CarPros. Is it possible? Yes. However most of the aftermarket units can mess up the factory alarm and anti-theft systems and even shut down the vehicle while it's running if they are not installed properly or if they use something like a security bypass.
If you really want it you might want to talk to a dealer about having the factory parts installed, that would let everything operate as it should without modifications. It is basically a couple of parts and some programming to make it work.
Sep 30, 2019 at 4:45 AM
BENJIE80
  • 5 POSTS
Thank you so much!
Jan 12, 2020 at 2:58 AM
STEVE W.
  • 15,388 POSTS
You are welcome. I've added factory features to vehicles and it is so much nicer when it's all OEM parts. I'vs also spent multiple hours removing aftermarket items that failed and caused various issues. Thank you for using 2CarPros
Jan 12, 2020 at 5:58 AM
