Audio amp fuse keeps blowing?
100,000 MILES
THIRD
Amp keep blowing the fuse.
May 17, 2024 at 5:44 AM
  • 110,251 POSTS
If this is an OEM amp, disconnect it and replace the fuse to see if the fuse still fails. If it does, then there is a short between the fuse and amp. If it doesn't fail, chances are there is an internal short within the amp.
Try this and let me know the results.
May 17, 2024 at 1:41 PM
THIRD
Disconnected the amp and fuse did not blow.
May 19, 2024 at 6:49 AM
  • 110,251 POSTS
It sounds like there could be an internal short within the amp itself. Make sure none of the connector pins are bent or making contact with each other. If they aren't, the amp will likely need internal repair work or replaced.
Sorry I don't have easier or better news. If the fuse isn't failing when it is disconnected, that is the most likely cause.
Let me know if there is anything I can do to help.
May 19, 2024 at 12:12 PM
