audible alarm wont shut off
140,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
NOTAPROMIKE
  • 66 POSTS
The audible alarm, ding ding ding, wont shut off in my car. I changed batteries and there are other messasges displayed on the dash such as air bag, parking brake. When I depressed the parking brake lever to release the brake, something snapped, broke. There is no resistance now on the parking brake pedal. How can I shut this alarm off? I don't want to fix the air bag or parking brake. It is a 1500.$ car. Thx. Notapro Mike
Feb 25, 2016 at 12:13 AM
HMAC300
  • 48,601 POSTS
you try hitting parking brake release if a handle then pull pedal up otherwise you'll have to grab parking brake cable with vice grips and pull cable to reset it.
Feb 25, 2016 at 1:46 AM
NOTAPROMIKE
  • 66 POSTS
Thanks. I will try it. On my other Bonneville the right side rear taillights quit working. The left side works fine. Are these fused separately? What fuse is it? I have 1fusebox under the hood on the passenger side and 1 under the backseat but none are labeled for the taillights. Thx. Mike
Feb 25, 2016 at 3:29 AM
HMAC300
  • 48,601 POSTS
they are fused the same check bulbs then see if there is power to it with brakes applied. maybe a short in system
Feb 25, 2016 at 3:59 AM
