1993 Audi S4 Question S4 tranny master and slave cylinders
1993 AUDI S4
VLADGEISER
  • 66 POSTS
Transmission problem
1993 Audi S4 Question All Wheel Drive Manual 140000 miles
I need to know where the master and slave clutch cylinders are as I believe I may have blown a line or destroyed one or both.
As I was driving I took the engine to 7000 rpm and tried to shift out of first into second, the car refused and ground on the synchro for a moment as I tried putting the clutch to the floor with no resulting shift. I can no longer engage the gears and there was a puddle of hydraulic fluid after I let the car sit in my driveway when I let the car sit for a few minutes after towing.
Mar 1, 2009 at 4:55 PM
  • 31,937 POSTS
Hi there,
I would say that you have blown out a slave cylinder check this first.
mark (mhpautos)
Mar 1, 2009 at 6:59 PM
PHILTYACK
  • 7 POSTS
try www.sjmautotechnik.com for lots of info
Jul 19, 2010 at 6:57 PM
