Drive Train Axles Bearings problem
2002 Audi Quattro 4 cyl All Wheel Drive Automatic
The inside boot on the driver's side CV joint has separated, so I can see inside the joint. I get a rumbling noise when I drive. Does the boot just keep dirt out, so that I could replace it and feel confident, or does it contain grease, so that some mechanical wear might have occured and I might need to have the joint replaced?
Apr 9, 2010 at 4:10 AM
