1998 Audi Quattro Headlights, blinkers, ac
1998 AUDI QUATTRO
135,000 MILES • 6 CYL • AWD • AUTOMATIC
PUZEN17
I have a 98 Ausi a4 quattro and all of a sudden the blinkers, headlights, ac, interior lights, and wipers stopped working. Is there something that controls all of these and could have went bad? Or is there something else that could be causing the problem?
Jul 13, 2010 at 8:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Unfortunately, there is no single fuse that protects all of these circuits. So that does eliminate the easy fix. What seems to be the problem is wiring issue in the steering column though. You will want to inspect the wiring in the column and use a tester as well as visually inspect them. One bare wire could short out the components there.
Jul 13, 2010 at 3:30 PM
