1997 Audi Quattro Alarm problem
124,000 MILES • 6 CYL • AWD • AUTOMATIC
SJAMBE3
How do I find and replace the alarm battery in my 1997 Audi A6 Quattro wagon? The alarm does not sound when I lock the doors or leave the head lights on after shutting the ignition off. However, it pings for about a minute when I start it and drive off. And I get a steady alarm signal for about a minute when I turn the headlights on. I suspect a bad alarm battery. Thanks.
Feb 19, 2008 at 3:38 AM
2CARPRO JACK
  • 11,533 POSTS
in the remote? the one in the car runs off the cars battery. Is this a factory or aftermarket alarm?
Feb 19, 2008 at 4:51 AM
SJAMBE3
I do not have the remote. I assume it's the factory alarm. I have owned the car for three years and have only heard the loud car alarm a couple times. I do not know how to use it. What I'm refering to is the warning indicator beeps you hear when you leave the lights on, or keys in the ignition, and the slight honk you hear when you lock the doors. I've heard there might be a separate alarm battery that, when it starts to die, cause odd things to happen. If there is no other battery, is there a way to reset the system? Thanks...
Feb 19, 2008 at 8:36 AM
2CARPRO JACK
  • 11,533 POSTS
The only thing I have is how to reprogrma remotes, not reset system without one. MFeb 19, 2008 at 9:23 AM
