HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Audi
A6
Engine Cooling
Thermostat
1999 Audi A6 Thermostat
JANZALO
MEMBER
1999 AUDI A6
6 CYL
AWD
AUTOMATIC
11,800 MILES
What are the steps to replace thermostat?
Monday, August 10th, 2009 AT 4:43 PM
DUBTECH
MECHANIC
Remove bumper
Remove a/c condenser and p/s cooler
Remove core support/ radiator/fan assembly.
Remove timing belt
Remove thermostat
Assemble in reverse order.
You should go ahead and replace the water pump while you are in there.
Monday, August 17th, 2009 AT 9:26 PM
Please
login
or
register
to post a reply.
Related Thermostat Content
Can Someone Please Tell Me Where I Can Find The Thermostat In An Audi A6 1999?
Asked by
sherrihooper
1 ANSWER
1999
AUDI A6
GUIDE
Thermostat
The thermostat is located on the engine either at the inlet or outlet radiator hose connections and is part of the cooling system, this unit is designed to stop the flow of...
1997 Audi A6 Thermostat
Need Help! Where Is The Thermostat Located On An 1997 Audi A6 Quarto? And How Is It Replace? I Have A Leak That Is Coming From The Back End...
Asked by
gentilee
1 ANSWER
1997
AUDI A6
2002 Audi A6 Thermostat
What Is The Easy Way To Change Out A Thernostat?
Asked by
audi76
1 ANSWER
2002
AUDI A6
Diagram Of A 95 Audi A6 Thermostat Housing Location
Asked by
Anonymous
2 IMAGES
1995
AUDI A6
1999 Audi A6 Coolant System Estimation
Air Conditioning Problem 1999 Audi A6 Hi, My Audi A6 Quattro Has A Coolant Leak And I'm Planning To Get The Entire Cooling/...
Asked by
malisonlor
1999
AUDI A6
VIEW MORE
How to Replace Thermostat
Thermostat Replacement Ford
