1999 Audi A6 P0302 Cylinder 2 Misfire Detected
104,000 MILES • 6 CYL • 4WD • AUTOMATIC
PARRISHACC
  • 5 POSTS
This is the code that AutoZone is giving me. But I keep getting this code and dont know what to do. I have replaced the ignition coil, new spark plugs, moved the #2 fuel injector to the #1 slot and still the same code comes on. I might just need new spark plug wires but I was told the were fine. The car also smells like its burning oil, I guess that cause its licking oil from somewhere underneath or rear. I just dont know what to do. The car wheel also rattles at speeds above 60mph.
Jul 10, 2010 at 2:45 PM
  • 75,988 POSTS
Check the compression for no.2 cylinder
Jul 10, 2010 at 2:59 PM
PARRISHACC
  • 5 POSTS
How Do I check the Compression
Jul 12, 2010 at 2:16 PM
PARRISHACC
  • 5 POSTS
I checked it to day at first it gradually went up to 150psi and then went to 120 and stopped then I did it again and it gradually went to 150 and stayed. I did this about 4 times and all had the same results.
Jul 18, 2010 at 11:39 AM
  • 75,988 POSTS
Is this both wet and dry tests? Also test the plug wire resistance
Jul 18, 2010 at 7:51 PM
PARRISHACC
  • 5 POSTS
No just Dry. and There was nothing wrong with the wires.
Aug 1, 2010 at 1:27 PM
  • 75,988 POSTS
Now check and test the injector
Aug 1, 2010 at 1:44 PM
PARRISHACC
  • 5 POSTS
Ive done that, I even moved the #2 injector to #1 to see if the code would change. Yet still the same code.
Aug 3, 2010 at 5:52 PM
