turn signal switch
FONZ388
1999 audi a4 1.8t at, hi i just bought this car and the turn signals and low beams do not turn on.hazzard button does work and turns on all the blinkers. the high beam light do work but you most hold the switch on. i do not know if it s a relay or the actual switch all fuses are good. please help
Nov 13, 2007 at 5:18 AM
FISHERMAN
  • 937 POSTS
[quote:4e72e5a35e="fonz388"]1999 audi a4 1.8t at, hi i just bought this car and the turn signals and low beams do not turn on.hazzard button does work and turns on all the blinkers. the high beam light do work but you most hold the switch on. i do not know if it s a relay or the actual switch all fuses are good. please help[/quote:4e72e5a35e]
Hello !!
Looks like the switch its faulty, and that involves a lot of work and care (air bag)..
The problem its that you can`t access that switch from outside, you have to remove the steering wheel..
make it reapair by a qualify mechanic.
Good Luck!
Nov 14, 2007 at 11:14 AM
DOCHAGERTY
  • 9,606 POSTS
If you intend to perform these repairs yourself, you might want to send me a PM or an E-mail and we can see if this could work.
Nov 14, 2007 at 1:18 PM
