2003 Audi A4 Check Engine Light
MICK BARRON
Does disconnecting the battery (2003 Audi A4)
reset the computer,thus turning the check engine light off?
Apr 19, 2007 at 7:26 AM
BACKYARDMECHANIC
  • 337 POSTS
disconnecting the battery will extingush the check engine light however the cars computer will have to re-learn it's operating parameters. Driveability may be effected untill the car re-learns it's operating parameters. Another draw back is if the condition that caused the light to come in the first time still exists, the light will only come on again.
Apr 19, 2007 at 11:02 AM
Suggested Repair
Disconnecting the battery can turn off the check engine light, but the computer must relearn its operating parameters and driveability may be affected until then. If the original fault remains, the light will return, so diagnose the cause rather than only clearing the light.
Conversation Summary
The owner of a 2003 Audi A4 asked whether disconnecting the battery resets the computer and turns off the check engine light. The expert said it will extinguish the light, but the computer must relearn its parameters, driveability may be affected until then, and the light will return if the original condition still exists.
