This is an issue with either the control unit in the dash or the blend/diverter door inside the HAVAC unit.
You could take out the control unit from the dash and probe the circuit board with a multi-meter, but I'm not sure of the specs/values so you'll have to hunt that down.
The entire HVAC unit will have to be removed to get at the blend/diverter door. Unfortunately this is an involved process and not all shops are going to be qualified to do this.
Tuesday, September 21st, 2010 AT 10:26 AM
