1997 Audi A4 engine over heating
SHAZSAAN
  • 1997 AUDI A4
  • 4 CYL
  • FWD
  • 132,000 MILES
Hi I have audi A4 1.6
car engine is over heating
machanic has changed the thermostat
know he is telling me to change the timing belt and the waterpump because the waterpump located unde the timing belt.I am realy shocked because my car has just pass the nct last month and hasnt been driving much from then
Saturday, March 7th, 2009 AT 7:20 PM
VLADGEISER
  • 66 POSTS
Water pumps generally fail in three ways, they leak, they seize, and they fall apart.
Leaking is easy, you will loose coolant, as your pump is next to the timing belt there will be a burning smell, though most importantly it will leak and you will loose coolant.
Seizing is easy to spot as it generally damages things around it, belts, hoses, loud nasty squealing sounds, this is seizing.
By falling apart I mean internally, such as the impeller falling off the drive shaft, or bearing giving out and causing grinding and leaking.
If your pump isn't doing one of these things I would get a second opinion on what should be done as there are so many things in a cooling system that can cause over heating, thermostat, radiator cap, bad hoses, head gasket, water pump, and on and on.
Thursday, March 12th, 2009 AT 1:43 PM
